I Have big problem in my harddisk.
my problem is when i connect the hardesk with my camputer then i can liesten the normal voice & can i see the power lamp but the computer ther not showing me this hard desk to insert ther ( On a computer screen ) .
I am try som way to solve it :
1.Chang the caple .
2.Try connect the same hard desk with ather comuter .
But the result is negateve and so bad for me .
Because there are important files in it for me.
Name of the device : My Passport Essential SE (USB 3.0)
Thank you for your interest
My name : Azoz
From KSA
