Hello folks,
I’m new here and new to using a NAS. I currently have a 3TB MyBook which is full…I purchased the WD Pro2100 16TB and I would like to find the fastest way to transfer from the MyBook to the Pro2100. I can see the Mybook in explorer (Win10) and I can drag files over to my shared folder on the Pro2100. However, trying to do this is at a very slow rate 5-20Mb/s. Since the MyBook is directly connected to the front USB port of the Pro2100, I figured this should go a lot faster. Is there an easier way to transfer the whole thing at a faster rate using the direct USB?
Thanks in advance for the help.
Jeff
You are now transferring everything via your PC.
It’s faster when you use a direct link (via your switch/router)
I use the following to transfer files at 60+ MB/s
Enable NFS on the old device (let’s say with IP address 192.168.0.100)
SSH into the PR2100.
Mount some path on the old NAS to a new directory /mnt/Oldnas on the PR2100
mkdir -p /mnt/OldNas
mount 192.168.0.100:/some/path/on/old/NAS /mnt/OldNas
Use rsync to copy folders from the old NAS to a new share.
rsync -a --progress /mnt/OldNas /shares/MyBrandNewShare
If you want to do this without keeping the SSH session open, you could use “screen”.
You can get screen with my entware-ng package as follows
opkg update
opkg install screen
A typical backup operation then goes as follows:
reconnect to screen if it was already running
screen -x
otherwise start a new screen session
screen
- start the long running rsync operation as described above
- disconnect from screen while the rsync is running by typing the combo CTRL+A and then D.
- feel free to exit SSH, the rsync operation will keep running until finished.
Good luck
