Help! Destination Drive Full Message but it's NOT full
Just installed MyPassport 1 TB using Windows XP Home with Service Pack 3.  I keep getting messages that the Destination Drive is full, but while showing the full message, it also shows there is over 900 GB available (and I’m only copying a small amount (less than 40 GB) total to it.  Please help.  Thanks!
Since there’s been no replies, maybe you should try contacting WD’s Technical Support about this. You can do so either by phone or email.
