My MBLD 6GB has been becoming slower and hotter over the last few weeks/months, and I also have troubles to connect it from my XBMC using either NFS or SAMBA.
I therefore decided to try to:
activate SSH and log in as root
move my data from my share to public, by doing: mv /shares/Data /shares/Public
run /usr/local/sbin/factoryRestore.sh noreformat , since people claimed it would keep their data
reboot.
N.B. : My MBLD was so far configured in RAID 1, hence having effectively only 3GB of usable space.
However, after restarting and getting a green light:
A) I can no longer access the Public share from an explorer window.
B) If I reactivate SSH and try to search for my files:
i) I can’t see the shares folder under /DataVolume
ii) I can’t see any share under /shares
iii) I can’t see any share under /nfs
C) When I go to the dashboard, it claims that I am back in RAID 0. But running parted shows only 3GB, so it seems in an inconsistent state. This makes me believe my data could still be around.
Questions:
Is there a way to get my data back?
Is there a way to safely rebuild the RAID1?
How to properly factory-restore is my case?
I had some important data on this drive which I would really get back.
Thank you very much in advance for your time and help!
If you cannot see the /shares/ directories with SSH, then you will need to remove the drive and access it with a SATA cable to a linux machine. Then use a data recovery software to get the data.
After having plugged either disk A or B in my desktop using a SATA cable:
Opening the disk using ex2fsd / Ex2 Volume Manager shows the drive as having a “RAW” filesystem. Nothing else can be done.
Linux Reader fails to read anything on the drive – probably because of the corruption of the filesystem, visible above.
R-Linux fails as well. I have done a full analysis of the drive and it managed to find some fragments of files, but there are in practice not usable and metadata (folder structure, filenames, etc.) have been lost.
I will do some more research and try some other things in the meantime, but:
Would anyone know any proven way to repair the filesystem in similar case?
