First I want to say thanks for all the work that was put in.
Right now I am using Syncthing to backup my files, but I encrypt it before as I cant verify that the community version is safe. Same for kernels.
I am trying to install debian on a WDMyCloud 2TB (firmware 2.x).
I found many guides about loading somewhere img or kernels.
Does somebody know how to do it from scratch, like only using scripts and debian.org as the source?
Does WD Mycloud need a custom kernel and not the normal armhf from debian?
Greetings and thanks for all your support
