Hello and Help please - WD drive no power
Hi
I have a WD hard disk and when i plug it in there is no power, it did not fall or anything.
It was working earlier, I pulled out usb socket to another drive by accident and put back in and no power
all other drive work
should i buy a new power supply
can the data be retrieved if new power supply does not work
any advice appreciated
If you are still under warranty call tech support regarding the power adapter.
