Don’t worry about it, Guy – it was a “user error”.
(The guy posted on so many threads it even confused me. Well, I’m EASILY confused :>)
rcarr wrote:
I was so excited to see that this Beta version was supposed to fix the MKV audio problem. I rushed home to upgrade only to find that in my case, it did not. I still have no Audio on my MKV files. I’ve gone under settings and verified the version number. I’ve also rebooted a couple of adddional time just in case. I also have a WD TV Live, and that plays the same MKVs with no problem whatsoever. I use Handbrake, all default settings. I’m not sure how that is effected if at all by the MKVMerge. Any ideas about what the issue might be would be appreciated. Thanks
For info, the answer was posted here:> http://community.wdc.com/t5/Firmware/WDTV-Live-Plus-Limited-Public-Beta-1-03-39-B-9-9-10/m-p/52344/highlight/true#M4377>
