Dear Sir or Madam,
Most new “WD TV Live Streaming Media Player” device access, as the latest firmware installed, I use seamlessly with projection device.
But,
Next time, I’m having a problem like this;
A “HDMI Switch” bought. WD between the projection device, I connected the HDMI switcher. In 1080p resolution, about 30-40 minutes after you start playing a movie, the WD device also turns out that my symptoms:
- slowing down menus.
- “insufficient memory, restart device” gives the message.
- And finally, the device freezes, crashes.
- I’m connecting the device disconnecting and reconnecting the power. But the problem is repeating the above. I am repeating the same vicious cycle.
As you also come to mind, HDMI Switch could also be a problem, I thought. WD ‘s dismantle, HDMI Switch’ to other devices (satellite receiver, etc.) Hooked. Whether I run tests for days. HDMI also Swich no problem, no problem. HDMI Switch is working properly.
HDMI Switcher got to do with lack of memory, I could not understand. Very strange problem.
I am currently on my WD device, I use without HDMI Switch, I had to use that. Without HDMI Switcher, I’m playing the same film, 1080P, no problem.
I’ve had such a problem, I want to let you know.
Best regards…
