HDMI Settings not sticking after hard power cycle
I am not optimistic that there is a fix for this. I am using my SMP with an older Toshiba CRT TV through a Rage HDMI to component converter. SMP HDMI is setup to 576p 50Hz / YcbCr / 8 Bit If I switch the AC power off at the wall outlet the HDMI settings are not retained. The SMP always defaults to 720p rendering the HDMI out of range for my TV. Anyone else seen this. Thanks Slip
Try before you turn off from the wall outlet, press and hold the button “Power” for 5 seconds.
Are you using the latest firmware.
Have you tried using composite video?
This is the way I power the unit down before turning off at the wall.
slip
1.09.10 fw
Yes I am using the composite as it’s the only way I can set the HDMI.
slip
