Do you mean via usb plugged into the ps3
I only asked about a TV signal to see if anything other than the HUB material was fuzzy or blurry.
BTW, there really is no such thing as an “HD antenna”, because the HD signal is on the same chennels as standard TV – just in a different format. What is important is the antenna must be of high enough quality to receive and deliver a strong signal to your TV, though. The proper antenna depends upon a lot of things, but that is a whole different discussion for some place other than the WD forums.
ok then but no nothing else is fuzzy except my wd as I said before my isn’t playstation 3 isnt fuzzy at all
Have you tried a different HDMI cable such as the one on your playstation that apparently works?
Have you tried viewing anything else other than your videos with the WD/? Like some videos from Netflix, YouTube or others?
If none of these ideas work for you, it’s likely time to call WD support.
