Hi all,
While trying to change the ip address on the device, I got error messages on the dashboard, then tried to reboot the device, it became irresponsive. When i checked the unit, the yellow light was blinking (i know this normally indicates presence of the cable/ethernet). I tried to do a hard reset (turn off and on the device while holding te reset button), still left with the yellow flashing light. This is not a cable problem, I replaced it.
Is there a way to fix this, or returning the unit is the only solution?
thanks,
James
