Hi there, dumb guy here…
WD TV Live Hub… Got it… Hooked it up… Loaded it.Eventually filled it… Used it for a few weeks then the other day the drive disappeared from “Computer” with windows vista.
The hub is hard wired to a router and I still have a connection to the web as I can still use youtube and other services and it even says I have a connection when tested
The whole thing works fine except I can not see it as a drive on my computer
The only thing that changed was SHE bought a laptop and connected to the wireless part of a different router than the hub is connected to.
This has been going on for a few days of on and offs, reboots, and I even deleted some stuff from the drive all to no avail.
I never set up a “network” and don’t know much about networking except I got this thing, plugged it in and after a little reading got it to work.
When I use the WD discovery program it says I need a password and I don’t think I ever made one… Whatever… I can’t seem to get any farther that way either.
I really want to see it as I did. Any ideas?
Please and thank you
