Hello All:
Quick question about replacing the drives if one should go bad…
I currently have the 12tb unit which is 3tb per slot…if one was to go bad, do I need to replace that with a 3tb drive or can I go bigger and have for example have 3 bays with 3tb and 1 bay with a 6tb drive…would that work?
Scott
