well story my second hdd caused problems like shut down with BSOD so i decided to check it with western digital tool but when i checked all my data have been lost and 2 partitions was access denied and said bad sector and then i decided to write zero on it then programme came with error sector … in write zero i restarted my system and made write zero again these time the write zero completed so after i formatted the had drive
i run spinrite programme and checked 1 partition which is C out of the 3 and didn’t check the other two because it would take long time but the first partition result was ok no error found
and again i run chkdsk and didn’t found bad sector but the problem now that in C: partition i can see there is 5 gb in use wbich is not normal because the whole hard drive is empty so how come there is 5gb in use in the drive C: which has no files inside it
in hdd tune pro says in reallocatted sector count current 200 worst 200 threshold 140 data 0 health ok
any help would be appreciated
