Several people are having issues with the available IP cam applications.
Here is a free, open source alternative: https://zoneminder.com/
You can install it with docker and SSH access.
Download and start the container
CID="$(docker run -d -p 80 quantumobject/docker-zoneminder)"
Get the port it is running on
docker port $CID 80
For me this shows
0.0.0.0:32769
Browse to this port, e.g. http://<PRx100_ipaddress>:32769
Then I added a camera, in this example I’m using my phone with the “IP phone camera” app.
The camera app shows that the camera is running on 192.168.1.105:8080
Open this address in a browser. Right-click on the camera field and inspect the html source.
It shows that the camera url is /videofeed
Now in the ZM interface, add a camera
- in general, set source type: remote
- in source, set hostname to the ip address of the camera, e.g. 192.168.1.105
- in source, set port to 8080
- in source, set base path to videofeed (or whatever your camera uses)
- in source, set the height and width correctly (see values from html source)
The source becomes green if you did it right.
