You need to download latest MyBook live firmware and install it again. Restoring to default settings will not do a trick.
Set up a Remote and Mobile access.
Reboot, verify if it works.
Install transmission. You are again no longer able to add new remote or mobile access, but previously set should work.
Thanks for your response. The problem is related with SSL connection. MyBookLive system is too old to allow new certificates system for SSL. Iām going to see if there is an alternative. If there is one you will need to test for me because I donāt have mybooklive anymore
Thank you for your reply but always the same problem at the same step. I link the error message below.
MyBookLive:~# vi setup.sh
MyBookLive:~# chmod 777 ./setup.sh
MyBookLive:~# ./setup.sh
./setup.sh: line 1: Install transmission bittorrent client on mybooklive - 2019 - Pastebin.com No such file or directory
Welcome! Compile and Install Transmission 2.84
Created by Proglin v2015-09-10
Last Update: v2017-06-14
ALWAYS back up your data before proceeding.
This script was only tested with MyBookLive firmware 02.43.10-048
Your firmware version is: 02.43.10-048 Thu Apr 13 05:44:51 PDT 2017
NOTE from Author: I have not MyBookLive since 2016. Changes after 2016 are based
on user forum comments.
We are going to change some configs to install Tranmission
This process takes around 30 minutes. Are you sure? (Y/N)y
I tested yesterday and it works perfectly.
Your error indicates that you are still on the old āsetupā file.
Try to delete and rewrite it as indicating by modifying step 4
Hi @Proglin thank you for your answer, and sorry for the delay but i had some internet issues.
Now i have an other problem at 7/22 look at this message :
Last Update: v2019-01-30
Iāve just fixed the original script from @Proglin to work again, but I think he was referring to the entire MBL data. If something breaks you could lose network access to the mybooklive, but you can always disassemble it and recover the data by attaching the hard drive directly to a computer
It is just a precaution if anything goes wrong because you are going to access your mybooklive using the ārootā. But as @milosgacanovic wrote if you somehow make some missteps you can disassemble it
Therefore I run into errors, I have downloaded the original versions of these files, and than just run the setup.sh, but I still got errors.
I think the problem is, that I just can run the setup.sh in bash for some reason. I can run anything on my NAS just like that, but this cause the problem, because I am in bash. But my knowledge is weak to fix this issue. So please help me to modify the setup.sh to able to run in bash, OR fix the issue with the NAS, and than I could run the original setup.sh or enything else normally.
This shell script just works in a ādefaultā firmware. So, if you tried to install and it fails you need to restore firmware to default one.
As I said here, I cant test the script anymore. I donāt know if they release a new firmware compatible with recent transmissions SSL requirements. Take a look here2
So, if you want to install version 2.84 you might try this script but, after rollback to a ādefaultā firmware state try to run: ./setup.sh instead of bash ./setup.sh
Thanks for the link.
I had to swap my hard drive to another one in the MBL, and I reinstalled the system with this method: [GUIDE] How to unbrick a totally dead MBL.
I am not able to update the firmware at all, always get an error message. So I stucked with a firmware which is a stock firmware, version 02.41.05-034 what was in the image file, but itās pretty weird, I am not able to run any script on it with ./, I have to use bash ./ and get these errors during running your script, it has problems with the if - fi command for instace etc.
