After installing as per the your instructions in Post #1, and after a reboot, I’m unable to add new mobile access (Settings → Remote Access → Mobile Access → Add Access).
Have you/anyone faced this issue? I get the following error.
31652 - Failed to generate code for your mobile device. Please make sure you do not have any network connectivity issues and try again.
If I update the same firmware from the file, I’m able to grant mobile access again.
in step 12/22 downloading sources of transmission the command failed, exiting.
The basic reason i tried to install again transmission was because for unknown reason the trasmission in my mybooklive duo start having issues with with connection port 51413. i tried to change that port to open it port forwarding but nothing work!
Any help please
ok I found the solution for both after i read the last post!
hi dears
i do all terms step by step but when enter: ./setup.sh i see this error!!! i try with all old & new code.
anyone know any fix about this happen???
& ihave a big problem when reset or power down on my hard when come back i lost my torrents file in download!!!
thank you so much
This is in continuation to the post I posted a year ago.
Is anyone else facing this issue, cause I am.
If I need to access the MBL via the WD My Cloud app, I will have to execute this /usr/local/sbin/factoryRestore.sh noreformat and then add start accessing the drive on the mobile.
Every time I do this, I loose all my users and shares.
I tried downgrading the firmware, it would not allow me to do so.
