[GUIDE] Sickbeard for MBL
This guide assumes you have already installed SABnzb following my guide
Most of this post is taken from http://community.wdc.com/t5/Netzwerk-Laufwerke/Guide-SABnzbd-und-sickbeard-auf-My-Book-Live/m-p/4838…
All credit goes to Shackles for the original post with minor modifications by me
For more information, see http://sickbeard.com/
Fire up PuTTY or Terminal
Change dir
cd /opt/share/
 Download the latest version of Sickbeard
wget https://github.com/midgetspy/Sick-Beard/tarball/master
 Rename
mv master sickbeard.tar.gz
 Extract
tar -xzvf sickbeard.tar.gz
 Remove download
rm -f sickbeard.tar.gz
 Rename folder
mv midgetspy* sickbeard
 In Putty type
nano /opt/share/sickbeard/config.ini
Then paste these 2 lines by right clicking your mouse button in the PuTTY window
web_port = 8081
web_host = 0.0.0.0
Hit control and o
Hit enter
Hit control and x
This will save the file
Now let’s start sickbeard manually
/opt/bin/python2.5 /opt/share/sickbeard/SickBeard.py
 Let it run for a minute or so and a menu will come up
 You may have to hit the space bar a few times to get to the menu
 Hit q to quit and when asked if you are sure hit y
 Hit Control and c to get back to the command line
 Now lets create the startup script
nano /etc/init.d/sickbeard
 There we enter the following text (right-click the way you can paste into Putty text from the clipboard):
#! /bin/sh
	#Required -- Defaults Provided (only change if you know you need to).
	HOST="0.0.0.0" #Set Sick Beard address here.
	PORT="8081" #Set Sick Beard port here.
	#Optional -- Unneeded unless you have added a user name and password to Sick Beard.
	SBUSR="" #Set Sick Beard user name (if you use one) here.
	SBPWD="" #Set Sick Beard password (if you use one) here.
	#Script -- No changes needed below.
	case "$1" in
	start)
	PATH=$PATH:/opt/bin:/opt/sbin
	 echo "Starting Sickbeard."
# use /opt/bin/python2.5/ if you skipped the Python update!
	/opt/bin/python2.5 /opt/share/sickbeard/SickBeard.py -q > /dev/null 2>&1 &
	stop)
	#Shutdown Sick Beard and delete the index.html files that wget generates.
	echo "Stopping Sick Beard"
	wget -q --user=$SBUSR --password=$SBPWD "http://$HOST:$PORT/home/shutdown/" --delete-after
	sleep 6s
	echo "Usage: $0 {start|stop}"
	exit 1
	esac
	exit 0
Now let’s set Sickbeard to start on a MBL reboot
chmod 755 /etc/init.d/sickbeard
update-rc.d sickbeard defaults
Now let’s restart Sickbeard
/etc/init.d/sickbeard start
Now in your web browser go to your mbl name or ip:8081
Set it all up
Done…
I don’t use Sickbeard so please feel free to post any setup instructions on how to set it up and integrate it with SABnzb
Hey!
Thanks for sharing.
Works perfectly, not a hiccup, integrates with SABNzb very easily.
An other great guide!
Thanks for the guide!!!
But sickbeard doesnt put the shows in a folder, atfter downloading sickbeard doesnt do anything but I have all the correct settings in Sickbeard. Can someone help me with this?
I first tried to install nzbget trough your guide (i have posted a question there) but i continue whit this installation.
After the step:
I get this:
-bash: /opt/bin/python2.5: No such file or directory
on my MBL there is a installation of python2.7
So i tried to adjust the path python2.5 to 2.7 in the line (i am a noob) then i get
 The Python module Cheetah is required
Can someone help me?
