I have v03.04.01-230 installed and attempts to install minidlna have broken my install. I followed the instructions, but the apt-get fails, and then I have dependency issues that I cannot clear up.
I took the plunge building MiniDLNA for firmware V4. For those who’s interested, basically below are the needed 64K page size memory packages to build. I’ll write a guide soon on how to install this when time permits:
nazar@TeaNazaR4TB:~$ find "../Public/Shared Downloads/WD My Cloud/Deb64K/minidlna_1.0.24/" -type f ! -path "*excluded*" -exec basename {} \;|sort
libavcodec53_0.8.16-1_armhf.deb
libavformat53_0.8.16-1_armhf.deb
libavutil51_0.8.16-1_armhf.deb
libdirac-encoder0_1.0.2-6_armhf.deb
libgsm1_1.0.13-4_armhf.deb
libid3tag0_0.15.1b-10_armhf.deb
libmp3lame0_3.99.5+repack1-3_armhf.deb
libopenjpeg2_1.3+dfsg-4.8_armhf.deb
liborc-0.4-0_0.4.16-2_armhf.deb
libschroedinger-1.0-0_1.0.11-2_armhf.deb
libspeex1_1.2~rc1-7_armhf.deb
libtheora0_1.1.1+dfsg.1-3.1_armhf.deb
libva1_1.0.15-4_armhf.deb
libvorbis0a_1.3.2-1.3_armhf.deb
libvorbisenc2_1.3.2-1.3_armhf.deb
libx264-123_0.123.2189+git35cf912-1_armhf.deb
libxvidcore-dev_1.3.2-9_armhf.deb
libxvidcore4_1.3.2-9_armhf.deb
minidlna_1.0.24+dfsg-1_armhf.deb
nazar@TeaNazaR4TB:~$ minidlna -h
[2014/10/30 00:44:21] minidlna.c:786: error: Usage:
minidlna [-d] [-v] [-f config_file]
[-a listening_ip] [-p port]
[-s serial] [-m model_number]
[-t notify_interval] [-P pid_filename]
[-w url] [-R] [-V] [-h]
Notes:
Notify interval is in seconds. Default is 895 seconds.
Default pid file is /run/minidlna.pid.
With -d minidlna will run in debug mode (not daemonize).
-w sets the presentation url. Default is http address on port 80
-h displays this text
-R forces a full rescan
-L do note create playlists
-V print the version number
I followed thses instrructions and it did not appear to work. It gave error message 1. My version of firmware is v03.04.01-230. I downgraded to this to allow another application be installed. Unfortunately I cannot show the screengrab of the messages as this forum does not appear to allow it. Could you maybe point me in the way of a solution?
