Reboot the cd again and don’t type any commands, Just fire up gparted and tell me where each device shows up and I will post coded lines you can copy and paste into terminal with a right click
ok like this:
mkdir space /mnt/usb
mount space -tvfat space /dev/sdb1 space /mnt/usb
cd space /mnt/usb
mdadm space -S space /dev/md0
./debrick.sh space rootrs.img space /edv/sda
Correct?
OK will do
Ok, GParted shows the two devices as:
2.73TiB hard drive = sda and is composed of
Partion unallocated 15.00 MiB
Partition /dev/sda3 unknown primary size 489.00 Mib with triangle exclamation point
Partition /dev/sda1 ext3 size 1.91 GiB used 585.69 MiB unused 1.34 GiB raid
Partition /dev/sda2 ext3 size 1.91 GiB used 585.69 MiB unused 1.34 GiB raid
Partition /dev/sda4 unkown primary 2.72 TiB used - unused -
Thumb drive = sdb
Partition Unallocated size 145.23 used - unused -
Partition /dev/sdb1 fat32 USB20FD size 29.73 used 1.92 GiB unused 27.81 GiB boot, lba
Ok here you go, copy and paste these into the terminal window one at a time (Control-c should copy and a right click and paste should paste the command into terminal)
mkdir /mnt/usb
mount -t vfat /dev/sdb1 /mnt/usb
cd /mnt/usb
mdadm -S /dev/md0
./debrick.sh rootfs.img /dev/sda
Ok, here is what happened:
root@sysresccd /root % mkdir /mnt/usb
root@sysresccd /root % mount -t vfat /dev/sdb1 /mnt/usb
root@sysresccd /root % cd /mnt/usb
root@sysresccd /mnt/usb % mdadm -S /dev/md0
mdadm: stopped /dev/md0
root@sysresccd /mnt/usb % ./debrick.sh rootfs.img /dev/sda
********************** DISK **********************
script will use the following disk:
Model: ATA WDC WD30EZRS-11J (scsi)
Disk /dev/sda: 3001GB
Sector size (logical/physical): 512B/4096B
Partition Table: gpt
Disk Flags:
3 15.7MB 528MB 513MB primary
1 528MB 2576MB 2048MB ext3 primary raid
2 2576MB 4624MB 2048MB ext3 primary raid
4 4624MB 3001GB 2996GB primary
is this REALLY the disk you want? [y] y
********************** IMAGE **********************
********************** IMPLEMENTATION **********************
everything is now prepared!
device: /dev/sda
image_img: rootfs.img
destroy: false
this is the point of no return, continue? [y] y
mdadm: /dev/sda1 appears to contain an ext2fs file system
size=1999808K mtime=Thu Jan 1 00:00:01 1970
mdadm: size set to 1999808K
mdadm: creation continuing despite oddities due to --run
mdadm: array /dev/md0 started.
mke2fs 1.42.7 (21-Jan-2013)
Filesystem label=
OS type: Linux
Block size=4096 (log=2)
Fragment size=4096 (log=2)
Stride=0 blocks, Stripe width=0 blocks
125184 inodes, 499952 blocks
24997 blocks (5.00%) reserved for the super user
First data block=0
Maximum filesystem blocks=515899392
16 block groups
32768 blocks per group, 32768 fragments per group
7824 inodes per group
Superblock backups stored on blocks:
32768, 98304, 163840, 229376, 294912
Checking for bad blocks (read-only test): 0.00% done, 0:00 elapsed. (0/0/0 errdone
Allocating group tables: done
Writing inode tables: done
Creating journal (8192 blocks): done
Writing superblocks and filesystem accounting information: done
mdadm: added /dev/sda2
synchronize raid… done
copying image to disk…
3999616+0 records in
3999616+0 records out
2047803392 bytes (2.0 GB) copied, 132.537 s, 15.5 MB/s
all done! device should be debricked!
Looks good
Screw the board back on to the hard drive with 2 screws and plug in the ethernet cord and then the power and see if it boots up before you put it all together again. Lemme know how it goes
The only thing that catches my eye is your data partition
It should be listed as an EXT4 partition like this
4 4624MB 3001GB 2996GB ext4 primary
You may want to make sure you can access your data after you recreate your shares and put the drive back together.
Well unfortunately it still won’t boot. I get the solid blue led and then a solid green led for quite some time instead of the normal flashing green led. Then it goes to solid red. I don’t know what else to do.
can you get to the dashboard? The red LED usually means the drive not being able to mount sda4 (the data partition)
Nope. No dashboard access at all. I’m going to try disk internals partition recovery on that partition and see what happens.
Well, it is probably going to take a while on this large of a partition. It’s up to (66) folders and (3,000) files and I can’t even see the progress bar green part yet. I’ll get back on it after the partition recovery completes. Nfodiz you are one generous fellow and I thank you for all of this help.
Barry
That was my next suggestion. Step 2 of my guide has a couple of programs that can pull the data off a MBL hard drive. DiskInternals Linux Reader is the easiest to use. In the case of a damaged partition R-Linux may work if DiskInternals doesn’t. I think testdisk is on the system rescue cd as well. There are also some commands you can try from the system rescue cd terminal window to repair the partition.
fsck /dev/sda4
The process should go through 5 passes and you will be prompted to fix things with a simple y or n
Pass 1: Checking inodes, blocks, and sizes
Pass 2: Checking directory structure
Pass 3: Checking directory connectivity
Pass 4: Checking reference counts
Pass 5: Checking group summary information
This should fix your filesystem on the datavolume.
I ran the reader first but it didn’t seem to be able to see or recover any files. Now I’m running the partition recovery wizard and it’s counting up the files and folders. Your post about which partition was showing up wrong guided me to which one to run the recovery on so thanks for that. Hopefully it will repair the ext4 partition and I’ll be good to go. There is 9 months worth of CAD work on this drive and it would kill me if I lose it. Thanks again Nfodiz. I’ll keep you posted on this. Up to (68) folders and over (7,000) files now. You see what I mean about lots of work.
Barry
The hard drive may be on its last legs which caused the original corruption to the drive as well so keep that in mind
should I cancel this disk internals partition recovery routine, reboot under the systemrescuecd and run that command?
Wow yeah I see what you mean. Keep me posted and I pray for the best
I’m not sure what effect that would have on the drive now that it’s in the middle of a recovery and I don’t want to walk you into a trap and you end up losing all your data.
Well it’s only 9 months old and I think a power outage in the middle of a read/write function Saturday night might have corrupted the partition. However, I guarantee there will be a double back up on these files this time. I now have a 3TB HDD in the computer and a second My Book Live 3TB. So echo echo everywhere.
That’s exactly what got the partition. I was gonna ask you if you had a power outage. It is most def fixable then.
