The following guide applies to WINDOWS XP, but every principle of getting the firewall/router, windows services, and User Permissions setup properly are the key stumbling blocks that applies to all versions of Windows to be successful in networking with WDTV LIVE.
Make sure you have Network DDE DSDM and Network DDE set to automatic and started in your SERVICES.
Also very important, make sure you DISABLE your firewall SERVICE in Windows. Not the check box in Windows that disables the firewall. That alone won’t do it. You have to disable the actual firewall SERVICE called “Windows Firewall/ Internet Connection Sharing (ICS)” located in your SERVICES. Don’t worry about your security. That windows firewall is only good for LOCAL traffic. It provides minimal to almost no security from the internet. Having this SERVICE on could give you a headache with your WDTV LIVE. And with routers nowadays, rarely does the average person need ICS either.
One note I should mention which I haven’t tested yet, is that I believe the “Computer Browser” service also needs to be put to AUTOMATIC and started.
Ok, moving on…
Turn Guest account or a user(s) account you created to ON
In your router config settings, do not use the DMZ in application support (port forwarding). Forward ports for each application or device in application support (port forwarding) instead. If you don’t know how to do that, don’t worry. Here is a website that will guide you for your EXACT ROUTER/ROUTER MODEM YOU OWN on what exactly to do. Pictures are included for every single step of what you will be doing inside your router or modem/router settings. This website is at www.portforward.com. Scroll down, select your modem and the rest you can almost do with your eyes closed.
This next part is optional, but may be necessary if you are also rrunning media servers/plugins. So, at the same website goto “Port List” and the same tutorials w/ pictures will guide you on opening up ports in your modem/router settings for your addons like Tversity for example, and Crackle, a Playon plugin, and other things you may have connected to your network. Ok, we are done for the router settings.
Now you need to setup your USER PERMISSIONS. Very important you get this right. But beforehand you need to disable “SIMPLE File Sharing” by clicking…
. Scroll down and UNCHECK the box “Use simple file sharing”.
moving on…
- Because most wouldn’t know which user or users to select to give PERMISSIONS to, just to be sure to get the right one, do the following steps below for each USER in your shared folder,
1 - Right click the folder in Windows explorer you want to share on your network
2 - Then click on “sharing and security”, then click the “sharing” tab.
3 - Make sure Sharing is enabled
4 - In same window click on PERMISSIONS
(NOTE: Before adding users, write down what users are currently there now before adding more users)
5 - Then click on ADD
6 - Click ADVANCED
7 - Click FIND NOW
8 - Highlight the USER for WDTV Live
9 - Click OK
10 - Click OK again
11 - Now you are back in the PERMISSIONS window. Select the USER that was just added to the PERMISSIONS window and allow aREAD ONLY permission by placing a checkmark in the READ box leaving the otther boxes unchecked.
Then reboot the modem/router first because of the changes made, then the PC or PCs, the WDTV LIVE in that order. After that it won’t matter which order you boot up unless you make drastic changes as indicated above.
Doing all these steps should resolve just about every network issue you may have with WDTV LIVE connected to your network. Let me know how well you did.
UPDATE 14/02:
INSTRUCTIONS WERE EDITED SINCE FIRST POSTED…
ptricks was good enough to point out that giving ALL permissions and adding every USER is not a good idea. I agree, so I would suggest that instead of adding every USER you see, just add one USER at a time to see if your WDTV Live works properly on the network with the shares/ media server. Doing it this way is a longer process going through all the boot process until you find the proper USER, but it is a much better way that won’t run you into other kinds of problems down the road.
And I also agree with ptricks, give only READ permissions when you are adding a USER to your permissions for WDTV LIve.
Thanks ptricks.
