And so I got “Your apache2 configuration is broken, so we’re not restarting for you”… Even worse, as I was searching for solution, later that day there is a power outage, and … the dreaded eternal yellow light comes.
Needless to say, then I followed this guide, and voila ! my MBL is back. Fortunately I haven’t had any datas inside yet
(then I followed your Installing Transmission guide, and everything went smoothly)
As stated in the guide, it will delete your data because it writes the OS from the start of the drive to 10MB into the data partition. The data may be recoverable but you should have done that before you followed this guide
The image contains all partition info and writes it all to the new drive when you use the dd command to write the image to the new drive which is sda or sdb or sdc as it has no partitions yet.
It may not boot on an 80GB Toshiba drive. Wait for your RED to come and try again.
You should just RMA your old drive if it is still under warranty as the hard drive was bad. (3 yr warranty)
dude - you are simply gr8! followed your guide for a mybooklive 2TB. almost missed the thingy with resizing and the sata cable at the bottom. followed the second step. now my disk shows 2TB and i am more than happy! a very big thanks to you!
Using this guide, my 3tb drive ends up as a 992gb drive, even after a qucik factory reset. I’m just trying a full factory restore and will report back. If it doesn’t work, how would I go about recovering the remaining 2tb of disk space?
Guys this GUIDE its amazing, thanks a lot for NFODIZ, the procces is as you said.
Its perfect.
In step 10 maybe you should consider a note that mention something like this procces may take a while or something like that. It is just perfect.
Thanks a lot.
Now a have a question. All my problemas began when i tried to intall Transmit. In the procces of Installation in Putty it said "“Your apache2 configuration is broken, so we’re not restarting for you”.
Now, With this guide of the same Member that wrote this topic (NFODIZ).
Tranmission Guide
Its safe to install whith the current firmware? i wont get troubles like the first time, right?
I’m not 100% positive that my transmission guide will work on the newest firmware as I have yet to try the newest firmware. It is surely safer than using apt-get to install transmission though so I would say give it a shot. It uses optware which is less prone to changing system files on the MyBookLive
Hi and thanks I managed to get most of it working but I have a 2t virsion and when booting back to grow the partition it just gives me corruption errors and will not complete so am stuck with 1t out of 2 ATM . Any more help on this
