[GUIDE] Debrick a completely dead MyCloud
#41
Ah, one is never too old to learn. Thanks for that, djh816. :slight_smile:
What do you say, shouldnt it be possible to convert my image using a call similar to?
xz -dc wd-my-cloud-6tb.img.xz | dd conv=sparse | xz -zc > new-image.img.xz
That should only take time ( a lot ), but not much disk space. What’s your opinion?
If you think that will work, I can do that an re-upload a new image.
#42
Yeah should work great as you mention. I may convert to .img.7z for sake of consistency but I worry about mirroring an image I can’t test :stuck_out_tongue: Anyways thanks for the source image. If nothing else they can follow instructions in your post :slight_smile:
#43
Alright, the operation is running. I hope I can post a new image sometime next week.
EDIT: I’m sorry, djh816. The conversion didnt go as expected. I still get an image thats 6TB big (uncompressed).
I also tried xz -dc wd-my-cloud-6tb.img.xz | dd conv=sparse | cp --sparse=always /dev/stdin sparse.img but to no avail.
Granted, I didnt bother to zero-fill the filesystem of the (brand-new) hdd before taking the image. But I dont think thats the reason (brand-new hdd). Otherwise, xz wouldnt be able to compress so well.
Another reason I might think of, is that I choose a rather big block-size (32M or 64M, I cant remember) when I created the original image.
#44
Hi guys,
I have a problem at point #9: Unfortunately, I can’t copy the image file from the usb stick because Linux doesn’t see any file on the stick.
I copied the image via OS X Finder on an exfat formatted stick and can see it there as well. The file is definitely on the stick but Linux just can’t see (and copy) it. I also tried to copy it with another NTFS stick, but Linux doesn’t see the file there, too. If I try to get an overview from all files on the stick with “ls -a”, I can’t see any files as well. Surprisingly, I can see folders perfectly but no files :frowning:
Does anyone have a solution for this problem?
Thanks a lot!
#45
Are you mounting the usb from command line under linux? Does that succeed? You could also try formatting the stick with Disk Utility on mac and using mbr partition scheme.
#46
I tried to follow this instruction with the 2TB Image and a 4TB HDD, but unfortunately I had to skip #14 and 15 because I didn’t received an error. After typing in unit s + p, I only got an overview about 2 existing sectors (not 4 as it’s written here). Furthermore, the start sector of the last partition (which was 2 in my case) was 77056s.
I continued with step 16 (but didn’t got a warning again) and finished the instruction, but currently I only get a permanent white LED and can’t connect with the software.
Do you have an idea what I’m doing wrong or another solution?
Thanks and best regards!
#47
Hi Djh816,
Your method worked for me to debrick 2 TB version. Thanks a ton.
#48
Hi, I need some help.
I bricked my 6tb wd mycloud, blinking red light.
I already tried different solutions, and I found the restore the img file the simpler (even because the other ones lead to dead links on necessary files).
Anyway I downloaded the 6tb image file from this thread (thank you), I used the gparted disk to have a working linux and completely cleaned the hd (5.16tb of unallocated space). I then restored the img file obtaining the partitioned hd. Put it back with the piece of board and still red blinking light.
I have also cleaned and recreated the ext4 partition, same result. I used the 2tb,3tb image file, both with enlarging or not the partition with the same result. I begin to think that for some reason my nas is different, maybe it needs a different firmware. I’m not an expert but I can run linux normally so I don’t know. The hd is perfectly working. I f***ed up the nas playing with ssh. My last resource will be to buy a synology enclosure in order to use the big hd.
Thank you in advance for the replies and excuse me for my bad english.
#49
There are two generations of MyCloud, and yes, they have different hardware and firmware, and they are not compatible.
Gen1 runs v3/v4 firmware. Serial numbers end in -00
Gen2 runs v2 firmware. Serial numbers end in -10. It was introduced about 21 months ago.
You need the right image and unbricking instructions.
#50
Thank you, I’ll check it out when I’ll be home. For what I can presume, I’ve the last one (nothing works…) so I can only wait that someone shares the relative image file because there isn’t a repository. My bad.
#51
Edit:
I found this working-life saving guide:
http://anionix.ddns.net/WDMyCloud/WDMyCloud-Gen2
Thanks Russia/Soviet Union !
WD MyCloud is back !
#52
@Tormie did the @Fox_exe method worked for you? I don’t know why I get stocked in the “uploading firmware” process. Gets stocked at 0%. Changes nothing after 4 attempts.
Does anybody have an image that works for the 2TB MyCloud Gen2?
#53
I used the method in the link of my last post, on the russian site. It worked perfectly.
#54
It didn’t work for me. I keep getting the same result. The “closest” I get to have the Cloud back is what is shown in this image.
I’m very open to ideas haha. And if you happen to have a virgin image of the device we both own would be much appreciated.
Thank you so much @Tormie
— Edit
You could see more details in this post: Clean OS (Debian), OpenMediaVault and other "firmwares"
#55
Hallo, thanks a lot, but I could do it with a new HD, also if the old one is broken?
gianki
#56
I think it’s not the serial number but the part number the one that ends up in -00 or -10.
#57
Great tutorial. You saved my day as well. Thanks!
#58
anyone tried this 2 tB img build to recover Mirrot gen2 ?
#59
Hi Djh816, Thanks for the great instructions! I’m not as Linux savvy as most here, I’m using a boot CD of Gparted live on a HP desktop and the 3TB image is on a ExFat flash drive. I’m stuck on step 7, I get either not allowed, no such directory or only root can do that. any more details you can provide? my WD drive is device SDA/SDA1/SDA4 ? and my USB is SDB/SDB1. Please help. Thanks
#60
Hm, you could try making the dir in /tmp instead. Basically to mount the usb device under linux you will first need to make a directory somewhere writable, and then use the mount command to mount the USB device there. Thanks for the feedback :slight_smile: Awesome that people can still get some use from this old tutorial
