CROSS COMPILING TRANSMISSION 2.82 FOR WD MY CLOUD
This is a guide to compile transmission 2.82 for the WD MyCloud 2/3/4 TB.
PLAIN TEXT VERSION: https://gist.github.com/sled/7745097
Because I didn’t want to install the build tools and dependencies on my NAS I chose to setup a cross-compiler toolchain on my x86_64 Ubuntu 12.04 machine and create a .deb package that can be installed on the NAS. Furthermore the cross compiler can be used to compile anything for the My Cloud (printer drivers, …)
However you need to turn on SSH on your NAS and accept the possibility that you might void your warranty by installing transmission on your NAS. I don’t take any responsibility for anything you do with this guide, your NAS and/or transmission
Host System: Ubuntu 12.04 LTS
Target System: Western Digital MyCloud, Concerto 2000 (ARMv7l, Cortex-A9)
If you are too lazy (and trust me (haha)), you can get the binary from my dropbox: transmission_2.82-1_armhf.deb (MD5: b543074596e6e02ffca02152fe274bf8). So you can jump directly to my second post where I show you how to install the package and configure transmission on the My Cloud
Install Dependencies for crosstool-ng
NOTE: I already had the build-essential package and everything else installed therefore I didn’t need to install any dependencies.
I took the depency list from http://smdaudhilbe.wordpress.com/2013/04/26/steps-to-create-cross-compiling-toolchain-using-crosstool-ng/
However, there are many guides available about how to install crosstool-ng on ubuntu.
IMPORTANT: All steps that follow now are to be executed on your local machine and NOT on the My Cloud!
sudo apt-get install autoconf automake libtool libexpat1-dev ncurses-dev bison flex patch curl cvs texinfo build-essential subversion gawk python-dev gperf g++
Create a Working Directory
Note: Replace with sled with your username
mkdir /home/sled/ARM
cd /home/sled/ARM
Install crosstool-ng
cd /home/sled/ARM
wget http://crosstool-ng.org/download/crosstool-ng/crosstool-ng-1.19.0.tar.bz2
Extract:
tar xjvf crosstool-ng-1.19.0.tar.bz2
Remove downloaded file to keep everything tidy:
rm crosstool-ng-1.19.0.tar.bz2
Go into crosstool-ng folder:
cd crosstool-ng-1.19.0
Configure and Make:
./configure --prefix=/usr/local
make
sudo make install
Tidy up:
cd /home/sled/ARM
rm -R crosstool-ng-1.19.0
Creating a cross-compiler
cd /home/sled/ARM
mkdir toolchain
cd toolchain
Option A: Use my config file:
Setup a basic config file by running ct-ng menuconfig
and exit directly with saving.
Now download my .config file and replace the hidden .config file (/home/sled/ARM/toolchain/.config)
https://gist.github.com/sled/7736747
Important: Adjust the paths beginning with /home/sled accordingly with a simple text editor.
Option B: Configure manually:
ct-ng menuconfig
Leave everything as is and configure as follows:
Paths and misc options --->
[*] Try features marked as EXPERIMENTAL
( ) Local tarballs directory
-> set to /home/sled/ARM/toolchain/src
( ) Working directory
-> set to /home/sled/ARM/toolchain/.build
( ) Prefix directory
-> set to /home/sled/ARM/toolchain/x-tools/${CT_TARGET}
Target options --->
( ) Target Architecture
-> choose "arm"
( ) Endianness
-> make sure it's little endian
( ) Bitness
-> make sure it's 32-bit
( ) Architecture Level
-> set to armv7-a
( ) Tune for CPU
-> set to cortex-a9
( ) Use specific FPU
-> set to neon
( ) Floating point:
-> choose hardware (FPU)
( ) Target CFLAGS:
-> set to -mfpu=neon -mfloat-abi=hard
( ) Default instruction set mode
-> set to thumb
-*- Use EABI
[*] append 'hf' to the tuple (EXPERIMENTAL) (NEW)
-> choose it
Operating System --->
Target OS
-> choose linux
C-Compiler --->
C compiler (gcc) -->
[*] Show Linaro versions
gcc version (linaro-4.8-2013.06-1) -->
[*] C++
C-library --->
C library (eglibc) --->
eglibc version (2_17)
Exit and Save config file (it’s hidden and called .config)
Build the cross compiler:
ct-ng build
Take a break and have a coffee, it will take about 45 minutes If anything fails, try to fix it and run ct-ng clean
before you try to build it again
The output from the build process:
sled@sled-MacBookPro:~/ARM/toolchain$ ct-ng build
[INFO] Performing some trivial sanity checks
[INFO] Build started 20131201.171932
[INFO] Building environment variables
[INFO] =================================================================
[INFO] Retrieving needed toolchain components' tarballs
[INFO] Retrieving needed toolchain components' tarballs: done in 0.06s (at 00:01)
[INFO] Extracting and patching toolchain components
[INFO] Extracting and patching toolchain components: done in 0.14s (at 00:02)
[INFO] Installing GMP for host
[INFO] Installing GMP for host: done in 46.41s (at 00:48)
[INFO] Installing MPFR for host
[INFO] Installing MPFR for host: done in 22.68s (at 01:11)
[INFO] Installing ISL for host
[INFO] Installing ISL for host: done in 23.08s (at 01:34)
[INFO] Installing CLooG for host
[INFO] Installing CLooG for host: done in 7.89s (at 01:42)
[INFO] Installing MPC for host
[INFO] Installing MPC for host: done in 9.45s (at 01:51)
[INFO] Installing binutils for host
[INFO] Installing binutils for host: done in 71.76s (at 03:03)
[INFO] Installing pass-1 core C compiler
[INFO] Installing pass-1 core C compiler: done in 355.79s (at 08:59)
[INFO] Installing kernel headers
[INFO] Installing kernel headers: done in 9.18s (at 09:08)
[INFO] Installing C library headers & start files
[INFO] Installing C library headers & start files: done in 24.26s (at 09:32)
[INFO] Installing pass-2 core C compiler
[INFO] Installing pass-2 core C compiler: done in 528.41s (at 18:21)
[INFO] Installing C library: done in 396.35s (at 24:57)
[INFO] Installing final compiler
[INFO] Installing final compiler: done in 695.28s (at 36:32)
[INFO] Cleaning-up the toolchain's directory
[INFO] Stripping all toolchain executables
[INFO] Cleaning-up the toolchain's directory: done in 4.41s (at 36:37)
[INFO] Build completed at 20131201.175609
[INFO] (elapsed: 36:36.90)
[INFO] Finishing installation (may take a few seconds)...
Once you are complete you will find the complete toolchain under /home/sled/ARM/toolchain/x-tools/arm-unknown-linux-gnueabihf, there’s also a version for the target system so you could copy it to your my cloud and compile stuff directly on my cloud without installing any build tools, but we won’t do this for transmission. Also this toolchain can be used to compile other stuff than transmission.
Preparing to compile transmission
We emulate the root folder / on the my cloud by creating a new folder called mycloud
mkdir /home/sled/ARM/mycloud
This means we get a folder structure like /home/sled/ARM/mycloud/usr/local/bin etc.
We create a folder to hold the source code for transmission and its dependencies
mkdir /home/sled/ARM/src
Compiling dependencies for transmission
We need a handful of dependencies for transmission:
- libevent
- zlib
- openssl
- libcurl
The order is important because cURL depends on OpenSSL etc…
Compiling libevent
Download and extract:
cd /home/sled/ARM/src
wget https://github.com/downloads/libevent/libevent/libevent-2.0.21-stable.tar.gz
tar xvfz libevent-2.0.21-stable.tar.gz
Go into libevent source folder:
cd libevent-2.0.21-stable
Setup Environment Variables:
export PATH="/home/sled/ARM/toolchain/x-tools/arm-unknown-linux-gnueabihf/bin:$PATH"
export cross=arm-unknown-linux-gnueabihf-
export CC="${cross}gcc"
./configure --host="arm-unknown-linux-gnueabihf" --prefix="/home/sled/ARM/mycloud/usr/local"
make
NOTE: You should see “arm-unknown-linux-gnueabihf-gcc” several times in the output if you only see “gcc” then it didn’t use the cross-compiler, make sure the environment variables are set properly.
make install
Compiling zlib
IMPORTANT: Close your old terminal tab and open a new one and set the environment variables again to make sure the correct ones are being used…
wget http://zlib.net/zlib-1.2.8.tar.gz
tar xvfz zlib-1.2.8.tar.gz
Go into zlib source folder:
cd zlib-1.2.8
./configure --prefix="/home/sled/ARM/mycloud/usr/local"
make
make install
Compiling OpenSSL
wget http://www.openssl.org/source/openssl-1.0.0k.tar.gz
tar xvfz openssl-1.0.0k.tar.gz
Go into OpenSSL source folder
cd openssl-1.0.0k
./Configure linux-generic32 --prefix=/home/sled/ARM/mycloud/usr/local shared zlib-dynamic -I"/home/sled/ARM/mycloud/usr/local/include"
IMPORTANT: Configure begins with capital letter here!
make CC="${cross}gcc" AR="${cross}ar r" RANLIB="${cross}ranlib"
make install
Compiling cURL
wget http://curl.haxx.se/download/curl-7.33.0.tar.gz
tar xvfz curl-7.33.0.tar.gz
Go into cURL source folder:
cd curl-7.33.0
./configure --prefix="/home/sled/ARM/mycloud/usr/local" --target=arm-unknown-linux-gnueabihf --host=arm-unknown-linux-gnueabihf --with-zlib="/home/sled/ARM/mycloud/usr/local" --with-ssl="/home/sled/ARM/mycloud/usr/local"
Make sure its configured with the following options:
curl version: 7.33.0
Host setup: arm-unknown-linux-gnueabihf
Install prefix: /home/sled/ARM/mycloud/usr/local
Compiler: arm-unknown-linux-gnueabihf-gcc
SSL support: enabled (OpenSSL)
SSH support: no (--with-libssh2)
zlib support: enabled
Now make it:
make
make install
Compiling Transmission (finally :P)
wget http://download.transmissionbt.com/files/transmission-2.82.tar.xz
tar xvfJ transmission-2.82.tar.xz
Go into transmission source folder:
cd transmission-2.82
./configure --host="arm-unknown-linux-gnueabihf" --prefix=/usr/local --without-gtk --disable-libnotify --disable-mac --disable-wx --disable-beos --enable-utp --disable-nls --enable-inotify --enable-utp --enable-lightweight --enable-cli --enable-daemon --with-zlib="/home/sled/ARM/mycloud/usr/local" PKG_CONFIG="/usr/bin/pkg-config" PKG_CONFIG_PATH="/home/sled/ARM/mycloud/usr/local/lib/pkgconfig" CPPFLAGS=-DTR_EMBEDDED
make CC="${cross}gcc" AR="${cross}ar" RANLIB="${cross}ranlib"
Now we create a nice little .deb package using checkinstall
(If you don’t have checkinstall, install it using apt-get install checkinstall
sudo checkinstall --install=no
Checkinstall will ask you a few questions that I filled in as follows:
--- SNIP START ---
The package documentation directory ./doc-pak does not exist.
Should I create a default set of package docs? [y]: n
Please write a description for the package.
End your description with an empty line or EOF.
>> Transmission
>> a lightweight BitTorrent client
This package will be built according to these values (most important is to set the Architecture to armhf, otherwise it won't install):
0 - Maintainer: [Simon - <schmsimo@gmail.com>]
1 - Summary: [Transmission]
2 - Name: [transmission]
3 - Version: [2.82]
4 - Release: [1]
5 - License: [GPL]
6 - Group: [checkinstall]
7 - Architecture: [armhf]
8 - Source location: [transmission-2.82]
9 - Alternate source location: []
10 - Requires: []
11 - Provides: [transmission]
12 - Conflicts: []
13 - Replaces: []
--- SNIP END --
When you are done the output should be:
--- SNIP START ---
Done. The new package has been saved to
/home/sled/ARM/src/transmission-2.82/transmission_2.82-1_armhf.deb
You can install it in your system anytime using:
dpkg -i transmission_2.82-1_armhf.deb
--- SNIP END ---
