sunky
August 24, 2013, 9:47pm
1
hi
is there any need for a gigabit switch if my laptop is already gigabit ethernet ready and jumbo frame disabled to speed up data transfer?
secondly
whats the maximum speed attainable if i use a gibabit switch (all device in chain gigabit enabled)?
i am currently seeing about 25MB/s, jumbo frame is disabled…anything else i can do to boost this speed?
cheers
Ichigo
August 25, 2013, 6:51pm
2
Where do you currently have the laptop connected? The transfer speed will depend on your network topology and the type of files that you are trying to transfer. I have seen users getting from 25 to 40MB.
Sunky,
You posted on the other topic but I guess you did not read the link provided. It is a bit old, but the concept still applies.
http://www.tomshardware.com/reviews/gigabit-ethernet-bandwidth,2321-3.html
