I have over 1.5tb worth of data to transfer to my MBL. From what I have seen so for, it might take days (1.5mb/sec on average) for this process to complete, something I think is absolutely ridiculous.
I dont think my router is gigabit enables, same goes to my wireless adapter. I have been reading incoporating a Gigabit Ethernet Switch will boost speed. How true is this considering the limited capability of my router and adapter.
Secondly, how do you make a wired connection with MBL? (MBL directly to computer) or (MBL to router and Computer to router)… does it actually help speed?
is your wireless adapter at least N capable? Is your computers LAN jack gigabit? It doesn’t matter what you have in between if your PC is limited from the get go.
I think youre best bet would be to go ahead and connect it via ethernet and see if your speed changes. You should see a MASSIVE increase in speed, even on a 100mbit connection. You could also try to WINSCP to the box and see what kind of speeds you get there.
