I just got the product, but i must say i’m very disappointed with my purchase.
I have WD TV Live Hub Media Center with firmware v 3.07.14
These are the some big issues that will prevent me to use it. and here they are:
1- There are no possibilities to make different playlists and use them. I can only add to queue what i want, but that’s it. Do i want a new playlist? i must rebuild all my queue.
2- There are surely isses with the firmware. If i select (for example for videos) repeat+shuffle in the setup, it won’t work. To make it work i must start to play a video, and after go to options re-select the playlist method i want, and then it will work.
3- If i set to make automatically play the queue i build at the startup of the WD TV Live Hub Media Center it won’t do anything else than play videos in normal order. i can’t make it shuffle. and also, there are no controls available during this playback, no FF, no REW, NOTHING!! i can only go back to menu and start to use in normal way.
4- Probably the hardware or the processor choosed by WD to build this devise is quite poor. Time between a video an another in the playlist take even seconds. The playback between one and another should istantaneous. We’re not talking about a device of 10€ with the hardware from last century.
I will get information with the dealer that sold me the product because i will have to return it.
I’m in Italy, the WD TV Live Hub Media Center is quite expensive, but the firmware is very bad and has big issues.
I’m very disappointed in this WD Product. i really thought i bought a great one, but i just spent a lot of money for a not-ready-to-sell.
This is my experience. If there is a way to fix all my problems, i’ll be so very glad to do somethig about this, and keep my very desired (well working) device.
