My G-Speed Q 8TB is shutting down after only 2-3 minutes. I can access my files, and all four hard-drives are working.
What can I do to get my data out?
Can I move my harddrives to another G-Speed Q?
If the unit is completely powering down then there is likely something happening to the internal power supply.
If you have another Q enclosure that matches yours then you can swap the drives into it and it will operate fine.
