Good morning all I have a usb 3 G-drive which has a power supply fault, I checked it with a second drive supply and it works so it is just the power supply that has died any idea where in the UK I can get a new one please?
You should be able to find one on eBay UK. Most likely from China at a price so low you can order two. Make sure you get the right 12v plug.
