My USB-A to USB Micro-B cable for my G Drive mobile is broken (don’t ask). Can I replace with any compatible cable such as Amazon Basic or must I use G Tech cable? If the latter, how do I order? Thanks
Yes you can use any cable that matches the specs, Micro B to A for instance.
