Hi all new to this, I have a wd live media player which freezes when connected to my wd 3tb drive, any suggestions on over coming this?
Hi, had the same issue when I first started using this SMP, if you take the drive and connect it to a PC (Windows 7) it should ask you if you want to repair the drive, this this then reconnect the drive to your SMP, then go into setup and system then Media Library and Clear Media Library, then go and turn it back on. This will cause the unit to re-compile and then you should be set to go.
Just be sure to select “Eject Drive” lower righthand corner of remote before unplugging drive, this causes the problem.
Thank you I’ll try it and let you know.
