There is an annoyance on these forums that doesn’t seem to get fixed copy and paste. It seems to be an ongoing problem. When I try and paste in a link for a post with a solution it seems to mainly highlight erythinng already written and paste deletes that or there is an error popup about source. Other times after paste there is no cursor. it should be a simple matter to fix these so it is more user friendly to use.
In order to check this effectively, I need some more information:
What browser and browser version are you using when this happens?
Does this consistently happen every time you try to do it? Or does it sporadically happen?
If it sporadically happens, do you know how to trigger it to happen?
Also, I’m not sure if I’m understanding what you mean, clearly. Can you provide any screen shots to show me what you are trying to do. Because I have no problems copy and pasting those links in a post. I will create a case once I get this this information.
