Hallo. I ned some help with a problem.
I now have my movies listed like this.
A / Moviename / Moviename.iso in that folder I also have a .jpg named folder.jpg
Now I want to change the way so my movie is listed like this
A / Moviename.iso
The problem now is that I am going to have lots of movie in the folder and I can only have one file named folder.jpg
What do I do to fix the folder.jpg problem ?
I am doing this be cores I want to use media libAry and the meta data service. The best way.
Instead of having all your movies in one big folder, why not organize your folders by genre like this:
Movies (folder)
Action (folder)
movie1.mkv
movie1.xml
movie2.mkv
movie2.xml
etc.
Comedy (folder)
movie1.mkv
movie1.xml
movie2.mkv
movie2.xml
etc.
This way you don’t have go through all your files just to get to one, and you can have folder thumbs for each genre.
Hi. I am not doing it in one big file. I sort them by the first letter.
A b c d …
I just need to find a way to get a cover for the movie. If I doesn’t get the metadata
But will this work to ?
Insted of
I can use
Moviename.iso and Moviename.jpg and still get the cover function to work ?
Then the same deal, just use a folder.jpg for the folder and then file_name.jpg for the file.
Movies (folder)
A (folder)
movie1.iso
movie2.iso
etc.
B (folder)
movie1.iso
movie2.iso
etc.
