Constant Flashing l.e.d light on MBWE 2 4tb. Wd Discovery software not finding network drive. These are the symptoms. I have only just bought this…please help.
Make sure it is connected into a wall outlet and not a power strip
also try downloading the dicovery software from the website dont use the cd that came with it
