Flash System LED?
Can anyone tell me what the “Flash System LED” setting is for?  It’s a new feature found in the system diagnostics section of the utilities options after the latest firmware update under the system logs feature.
Nevermind I tested it after it finished rebooting. I can understand a single command that says “Flash System LED” where it might cause it to flash for a few seconds, but what is the purpose of the On/Off toggle switch. Under what conditions would that be beneficial for a user to leave it in the “on” position?  Wouldn’t hurt to put a note on the feature that says “This will cause the system LED to flash continuously”.
