FLAC file audio player problems
My WDTV is running 1.03.01 firmware.
I use my WDTV for audio playback and I have the following problems:
  1. FLAC playback of some files stops mid-song.  Playback continues with the next file.  This is repeatable and is by far
    my biggest problem.  I cannot use the player with this problem!  The files are normal 16bit/44.1kHz files.
2. Song titles with accented characters in the file names/metadata cannot be included in playlists.
  1. I cannot get any album art to work in “now playing” for my FLAC files.  I have art files of the form "full album
    name.jpg" in the folder containing the FLAC files.  I have also tried “COVER.JPG” as described in the
    documentation.
Help, Please!
Have you searched the rest of the forum about this? I’d give it a try. You can also contact WD’s Technical Support by phone or email.
hi,
would wd tv live be acle to list all the songs on a single FLAC audio file? aka load the *.cue file along with the main audio source file.
right now it is not possible for me.
thanks :slight_smile:
