Hello , new to forum ;searched and found the realted subject but as the article is old couldnt post my question
I have been looking up for a media player to run my FLAC files in CAR Stereo system so looking at WD Live in this aspect.
Since I will use the player for stereo sound , video options are not so much important , will only get normal video output just to see the file name playing.
I will use the Spdif output of the WD Lİve and transfer the sound to my DAC device for further sound processing ,
my target is to play
16 bit 44 Khz ( CD quality) and
24 bit 48 Khz files format.
My DAC ( Audison bitone) optical input accepts max 24 bit 48 Khz , anything higher is not accepted but lower is no problem. But some files I have will be 24 bit 96Khz.
Questions:
1- Is it possible to fix the frequecy sampling rate of WD to or untill 24 bit 48 Khz ? I mean , in case of need ; Can it downsample higher then 24 /96 Khz to 24 /48 if requested once. If yes do we need to arrange this setting on every startup.
2- Does anyone know / help about he Total jitter amount of WD Live ?
Thanks for any input
