The 'QuickBooks won't open' error does not allow the users to carry tasks on their QuickBooks. At times your QuickBooks does not open even after several attempts. You should note that this error can occur if you click on the QB icon multiple times before allowing it to load. So make sure you are giving it enough time to load before you keep tapping on it. With this detailed guide, we will help you fix this error from your desktop. You can also learn the causes and symptoms of this error in this blog.
You can take help from our experts if you are looking for immediate assistance to fix the QuickBooks won't open error.
Causes that instigate the QuickBooks desktop won't open error
These reasons can be the root cause of the error.
- A damaged hard drive may be the source of the error.
- If your desktop has internet access problems, your QB may crash.
- The 'QuickBooks desktop won't open' error may appear if there are compatibility problems with the program and Windows.
- This error may occur when your company file name is too long or contains special characters.
- Determine whether a lack of operating system updates is the reason for this error.
What are the effects of the QuickBooks won't open error?
- QuickBooks can freeze or hand off due to this error.
- Your operating system will respond slowly.
- The active programs might crash.
How to rectify that the QuickBooks desktop doesn't start an error from your desktop?
Go through the solutions and implement them on your desktop to eliminate the QuickBooks desktop doesn't start error. Suppressing the QuickBooks desktop can also help you fix this error in your QuickBooks.
Solution 1: Utilize the QB diagnostic tool
- Go to the installation difficulties section of your QuickBooks tool hub after accessing it.
- Choose the 'QB install diagnostic tool,' then permit the tool to operate. The process of finishing the tool can take some time.
- Restart your computer, then run QB desktop. Once it has finished, view the data file.
Solution 2: From the tool hub, operate 'quick fix my program’
- If your computer does not already have a tool hub, download it. Complete the tool hub installation, and then access it on your system.
- When you access the tool hub, go to program problems. On your computer, look for a quick fix to my program and launch it.
- At the end of the procedure, restart the QB desktop.
Final words!
This blog will help the users to have a brief about the QuickBooks won’t open error and also help you rectify it. Our support team is available for your support and assistance 24/7. With their help, you can resolve all your queries. If you still cannot fix this error.
