Fix for My Book Freeze. Twonky setting;
Problems with Mybook Freeze. Hangs after a couple of day’s, Twonky not working, then
VI
/twonky/twonkyvision-mediaserver.ini
change “streambuffer=16384”
Reboot
Chris
Try the latest firmware here is a list of all the fixes
http://www.wdc.com/wdproducts/updates/?family=mbworld
the firmware does not fix that, there are lots of thread about the freezing problem.
I’ve also tried the solution suggested but my hd freezed once.
i’m still waiting to see if something changes.
krum09, your hd is still running ok?
Yes it still working, I am happy I doubt I will buy another WD NAS though
Chris
Chris, if your’s still working, do you mind come here and share your experience?
http://community.wdc.com/t5/My-Book-World-Edition/WD-World-Edition-white-light-freezes-locks-up/td-p/99198
sounds like you’re the lucky guy here.
