Only my WDTV Live on 1.06.34. Everything else on the network is still a member of the STRAYLIGHT workgroup.
This is where the confusion is about what I did and what you have said in many posts.
I ONLY changed the name of WORKGROUP on my PC.
Workgroup is still just WORKGROUP on the WDTV unit.
Again. ALL settings in WDTV are as they have always been.
ALL router settings have stayed the same.
ONE change was made on my PC and that was the name change of WORKGROUP
Again. Not sure why it worked since the name is different but it has.
Today I am going to change the name back to default on my PC (WORKGROUP) and see if my network shares stay or dissapear again.
So I changed my PCâs Workgroup back to itâs default of WORKGROUP name and guess what ⊠NO NETWORK SHARES !
As many have said, this should work since it matches my WDTV unit Workgroup name (WORKGROUP) but it doesnât !
So changed it back (my PC) to WORKGROUP-PC and guess what ⊠got my network shares back.
So how and why is unknown to me but Iâll take it since I can stream from my PC as I once used to.
Iâm willing to bet itâs the units firmware gone haywire or something. I donât care really since it works.
There is no confusion about what you did or why it works but about why it does not work if you go back to using WORKGROUP. As weâve established, this firmware apparently doesnât need all devices to be in the same workgroup any more, however thereâs no reason for it not to work when all belong WORKGROUP. Of course you should stay on what works for you but the whole situation doesnât make it any easier to find whatâs causing this. Iâd really like to see anyone else chiming in solving the problem like you have.
If youâre willing to experiment - how about if you rename it from WORKGROUP-PC to something like TESTGROUP, anything as long as itâs different from what your WD TV is using?
As far as I can recall, the Live / Live+ didnât have a workgroup limitation like the SMP and Hub have â itâd work on any workgroup.
Changing your PCâs workgroup name is going to cause your PC to be the master browser of itâs own workgroup (WORKGROUP-PC), while some other device on the original workgroup (WORKGROUP) will become the master browser of that workgroup.
The implication is that your PC doesnât play master browser correctly when itâs the master of a larger workgroup, but works OK when itâs in a standalone workgroup.
That was my impression until some people mentioned it here and since WD also backported some weird stuff with the SMP I thought it was possible so I switched after updateding. As it turns out my network troubles were due to my router so now that itâs fixed being in any other workgroup works as well.
What was your issue with your router ?
I have said before that this network issue did in fact come about after installing a new router. I just didnât think it was the issue since network connection was checking out on the WDTV (check network connection option) and that I could also see my WDTV and the USB drive hooked up to it, from my Windows machine through Network Neighborhood.
I went from a WRT120N to an EA3500
I just dont get how the PC can communicate to the WDTV with Workgroup names macthcing but not the other way around. Then how it communicates both ways with 2 different names ⊠? Boggles my mind hahaha
linksys huh ?
I had constant problems with the E3000 until I installed DD-wrt
but DD-wrt is a mess of itâs own
definetely not for everybody
Well, workgroups are a pointless invention by Micros~1 that have no actual bearing on network connectivity. The problem with my router was that with frequently changing LIVEs and firmwares on the network and assigning IPs via DHCP, it apparently got confused which device had which IP (probably due to lease times). So I deleted all devices from the routerâs network list, added them one by one and set the router to always assign the same IP to the same device. Since then I had no trouble accessing network shares no matter the workgroup.
I am running firmware version 1.06.41_V on a WDBAAP0000NBK box. (B good if yo all left this info)âŠ
This may be relevant, about 3 weeks ago I installed this FV (no choice) and could not see any of my network shares. Then after a few days I noticed that I was able to access all my folders / files via the media server , I do not remember looking there for them before but they all worked well.
A week passed by and I read a post here that  suggested executing the âClear Login for Network Shareâ which I did and a few hours later my network shares were back. This was all OK until a power cut the other day and now I am left with accessing my files via the media server again (which is not a big issue and if it is I donât know what it is yet), by the way I have tried " Clear Login âŠ" but to no good.
One thing I want to ask you all is if you are able to access all your shares via the media server?
I think micorsorft runs this app by default, but I may have turned it on yonks ago.
__________________________________________________________________________
Firmware version 1.06.41_V on a WDBAAP0000NBK box.
must get it right 1st time
For me, I was never able to get past the Netwok Shares icon. I could not choose my PC (would not âmove overâ) and I did try and see if Media Server worked but again the same issue. Could not âmove overâ to a selection.
So I ws left without any type of networking.
Have you tried the method I talk abot in here ? Im curious for those who can not acess their shared folders find this a fix like I have.
WOW, Great news my Network shares is also working!!!
In short the answer to your question is no, butâŠ
WDTV619 wrote> xxxxxxxx
Have you tried the method I talk about in here ? Im curious for those who can not access their shared folders find this a fix like I have.
⊠I went off to my PC to change the workgroup as you suggested, then remembered something about setup files for the WD and thought they were on my laptop, I opened it up, but could not find the relevant files. So, being a little confused as usual, I went to the WD box and looked at my Network Settings again. I thought to myself, even though my WD box never changes its IP, since its always been on automatic, what would happen if I changed it to manual?
Well, the first thing was that the radio stopped playing and I thought what the **** now, not another WD special (as one has to now) so off I went to the radio and amazingly got it going, then thought where was I, I know trying to get to my Network shares. So, I went to the Network Shares and all my shares came up including some I did not realise I had shared. Tried some audio, photo and not video yet but what I did try worked.
I am totally gob smacked, where did that come from just changing from Automatic to Manual, no changes in the values offered, a simple change Automatic to Manual and press OK.
Anybody dare to explain?
sounds like a problem already described above with the DHCP lease
set the IP to static, means itâs not using DHCP anymore
