Firmware upgrade: no usb key detected, no upgrade icon appears
Hi !
I’m trying to upgrade the firmware on my WDTV player.
The firmware that’s currently active on the player is:  1.01.02
I downloaded the current official release: 1.02.21
I copied the 1.02.21 firmware on a formatted in FAT32 USB Key, to the root directory (document  “How to Install the Product Update.doc”);
as far as I read, the player should detect that there is a newer release and should show the “firmware upgrade icon”.
Nothing happens: I tried with different USB keys, but I couldn’t see that icon anywhere.
Can anyone give me a piece of advice or suggestions.  I’m getting a bit crazy about that.
thanks in advance.
ciao from Sestrieres, Piedmont, Italy
What’s the model# of your WDTV?
Also, does the USB light come on / flash?
If the USB light never comes on, then the WDTV isn’t recognizing the thumbdrive.
… also, it’s THREE SEPARATE FILES, right?
Um… if it’s for a Live, doesn’t the 1.01.77 _ HAVE _ to be installed before the 1.02.21 can be applied?
It was 1.01.17, and I know it did that with the INTERNET downloads, but I don’t think you had to do that for USB loads.
thanks for your prompt intervention.
So , here’re the answers:
     Q: What’s the model# of your WDTV?
     → wdavp00
     Q: Also, does the USB light come on / flash?
     → yes, definetively yes
    Q: … also, it’s THREE SEPARATE FILES, right?
    → yes: I put to the root the three different files I extracted from the download zip: the .BIN, .VER, and .FFF files
hope this can better clarify the situation.
thx
ciao
Ok, I typed it wrong… I knew something came up from the Internet as soon as I got my Live unboxed.  I didn’t know that there weren’t the same pre-requisite conditions for USB 1.02.21 as there are for Internet 1.02.21.  Now I know. :smiley:
That’s not a WDTV Live, so that firmware isn’t going to work.
I believe that’s a PAL version of the WDTV HD Media Player, so you’ll want to look HERE:
http://www.wdc.com/en/products/wdtv/
I’m gonna download it right away and try it.
I’ll keep you informed soon.
ciao
… some minutes later …
GREAT: that’s it.
It was a “pal” version problem. I didn’t image it at all: how silly I was !
THANKS THANKS a lot :smileyvery-happy:
it was very kind of you: I appreciate.
ciao … a guinness is waiting for you in the middle of the 2006 winter Olimpic games mountains.
