Hello again,
After wasting 4+ days (I’m not even sure) I think I’ve managed to strip as much as I can and ended up with a minimal installation with (hopefully) great standby time (still testing) and even greater performance.
http://levo.pro/2017/05/13/barebone-my-cloud-gen1-fix-sleepstandby-problems-and-more/
1- disabled as much service as possible, including:
– afp: performance hog, smb3 works great with mac os.
– nfs: never used
– ftp: ssh already offers sftp
– external usb: never used
– logs: waste of memory, never checked before
– winbind: I don’t have any PCs
– cron, media server, etc.
2- cleanup: removed some obvious useless files/folders. once you do it, it may take 10-20mins to reboot, don’t worry and just wait for file system check to complete.
3- ramlog: dropped its size to 10M to prevent swapping.
4- samba
– applied msg.sock tmpfs fix, integrated to init.d samba file
– disable spoolss: disables printer support: improves disk standby time
– added streams_xattr: gets rid of dot underscore files, lightning fast directory listings, and drops cpu usage
– increased deadtime: default is unlimited, improves disk standby time
– disable netbios: disables nmbd which improves disk standby time
– disabled log file: save memory to prevent swapping
5- mDNSResponder
– added smb & removed afp: connect from sidebar
6- monitorio
-– removed tally (/usr/local/bin/tally doesn’t even exists)
–- removed mediacrawler
-– removed individual share size calculations
–- disabled rotateLogs (run-parts /etc/nas/wakeup.d)
–- mount / noatime,nodiratime
–- decrease vm.swappiness
–- added afp fix (killall cnid_dbd) (if you decide to keep afp, this one prevents spin-ups)
–- added sleeptime logging (/var/log/monitorio.log)
–- added log truncation
– decreased swappiness: keep it in memory
– stop cron (a couple scripts restart it)
– added debug mode: stop the service and run it from terminal to pinpoint processes that read/write
Results:
- no more 7 seconds sleeps
- stays asleep hours (hopefully will standby days)
- read/write speeds jumped from 55/40 to 100/85 (due to low cpu use)
Once again, thank you Bennor, rac8006, and Ralphael!
Bonus: https://dl.dropboxusercontent.com/u/81196443/WD%20My%20Cloud%20Files.zip
