I just bought an installed My Cloud 4TB, single bay with FW 2.12.xxx. It started fine with shutdown option. I’m running Windows 10. I mapped the new folders on it to specific drives and I can still see them on my windows Explorer.
I couldn’t see any shutdown option on the control panel and I was already using WD Smartware (old software cos the new software wouldn’t eject My Passport properly) which came with QuickView. It had the shutdown option so I managed to use it to shutdown once. The next time I started up the drive and pc, the shutdown option and the driveitself disappeared from Quickview. I can still see the mapped folders and access them fine but I can’t shut down still.
I tried updating Smartware but still no shutdown option and now My Passport is not ejected properly either. I tried updating the FW to 2.21.119 and still no shut down option. I tried installing WD Access, still no shutdown option.
The other problem I had was when I tried rebooting MyCloud on the user control page, it is permanently stuck on rebooting even after the light on the device goes back to non-blinking blue light. I have to restart my pc before I can access the user control page again. Now I have to shut down pc and then pull the plug to turn the drive off.
Is there actually a solution to actually shutting the NAS drive down from PC itself?
If one uses the forum search feature, magnifying glass icon upper right, they’ll see the issue of the missing shutdown button with the v2.x firmware single bay My Cloud units has been discussed at length with several options to shutdown the My Cloud.
Ya, I did a lot of searches and reading of the multiple threads. The problem is My QuickView doesn’t even see the drive and so I still don’t have the shutdown option even with the updated Quickview.
Try uninstalling QuickView. Then disconnect/eject the My Passport from your computer. Reboot the computer, do not reattach the My Passport at this time, reinstall the latest version of QuickView downloaded from the WD Support link (Windows): http://downloads.wdc.com/nas/WD_Quick_View_Setup_for_Windows.zip
Then check to see if QuickView can see/access the My Cloud. If not then check to see if the computer’s firewall is blocking QuickView access to the local network. If QuickView can see the My Cloud then reattach the My Passport drive and check again.
Thanks?? Partial solution? Tried the suggestion. After reinstalling the newest Quickview, MyCloud was detected and seems ok. Plugged in My Passport Essential and both showed up in Quickview. Yeah! Great! Transferred files from Passport to Cloud and then tried to shut down, Cloud disappeared from Quickview. Ok…tried ejecting Passport first and then Cloud appeared back in Quickview with shutdown option but Passport still showing in Quickview and drive still spinning but not showing up in explorer and Quickview says 0% free space in Passport now…???
…ok…shut down Cloud using Quickview, exit Quickview and used Windows safe eject for Passport. Drive ejected but lights still blinking. Spinning seems to have stopped but last time I unplugged My Passport while lights were blinking, it got corrupted and I had to get it replaced so I dare not unplug Passport.
Long-way round to shutting everything down safely but manageable. Thanks anyway.
