You are wrong Cybernut - I never said I added files to the .wdmc folder you are putting words in my mouth.
This is however not the issue here.
If you carefully read the prevous posts to this thread,
for instance the following:
IF Cloud Access is turned ON,
AND whenever it is changed from OFF to ON,
folders that contain *.jpg files and possibly other “media” files
will have .wdmc folders added to them.
in my post from 10-30-2014,
That is what happened, automatically, I could have swore I said “without my concent” oh wait, I did, how ironic, what does this say;
Who said I added files to a .wdmc folder, why would I do such a thing, it was done without my concent !
I knew what the command does, it’s pretty straight forward, you don’t have an edge with regards to knowing a simple command, just to let you know !
You don’t have any reasoning as to why; if it didn’t happen to you, my media files, specifically JPEG files are gone, the only answer you give is, learn what commands do; or I copied the files to those folders intentionally. They are gone and you haven’t given an answer, even a simple, you were unaware, and you were partially wrong answer would suffice.
I bought this device for the same reason as everyone else and if a command fails or people could loose their data, they have a right to know, the command is not supported by Western Digital so it’s not as if customers can call WD for support on this issue, they either live with it; or, yes; risk loosing their data unless it’s backed up, now that they are aware of the consequences, and have every right to be; unless it can be retrieved which I doubt.
Please don’t threaten that you control the support pipe and I should be run by fear.
