FIRMWARE ROLLBACK GUIDE FOR THE WDTV MEDIA PLAYER (2014)
1. small flashdrive (2,4,8 GB) formatted FAT32 … completely empty
2. download rollback firmware: http://download.wdc.com/wdtv/wdtvlive_rollback_1.01.30.zip
3. extract all 4 files onto the root of the flashdrive ie. No Folders
so you should only have these on the flashdrive
wdtvmediaplayer.bi2
wdtvmediaplayer.bin
wdtvmediaplayer.fff
wdtvmediaplayer.ver
4. Before inserting the flashdrive … check the detect New Firmware setting is “On”
Setup > System > Auto Detect New Firmware > On
5. Power off the WDTV (Press and hold Standby button for 5 seconds … switch off at the mains power)
6. “Safely Remove” the flashdrive from your PC and insert it into the front or rear usb input on the WDTV
7. Power On the WDTV
8. New Firmware should now be detected “New Firmware” notification will appear in the Home Menu (if using Grid UI there will be a Orange System Alert Icon at the top right of screen) Navigate to it and Press OK.
(it will say 4.01.30… don’t worry, ignore it) … press OK to proceed)
9. wait until finished (it can take several minutes … it should not take longer than 10-15 min)
10. It’s also recommended after a Firmware Rollback (or upgrade) to do a Factory Reset
Setup > System > Device Reset > Reset All Settings Back to Factory Default
11. when finished (optional) disable the New Firmware notification
Setup > System > Auto Detect New Firmware > Off
