I don’t think this is a firmware issue. I was having exactly the same problems running v3 firmware. Last night I updated to the v4 firmware and I still cannot establish a remote connection.
¿ Pudiste solucionar el problema ?. Saludos.
Could you solve the problem?. Greetings.
Si. Era un problema de los servidores de WD
Angel
Yes. It was an issue with WD’s servers.
Just in case you’re not sure if the servers are down, there is a link up above that takes you to a server status update page to make sure there are or are not issues with the servers.
I’ve been running firmware version 03.04.01-230 on two MyClouds. I had no luck with various version 4 updates and found I had to downgrade to V3 to get my safepoints to run on attached USB drives. I finally decided to upgrade to 04.04.04-101 and can report that everything went smoothly. Both devices recognise the USB drives and safepoints are working. Well done WD!
