Hi, I have the Gen1 My Cloud Mirror running firmware v2.11.164 (as of this writing, this is the most up-to-date FW version available for my NAS device).
According to the actual User Manual available from the Product Page here: WD Documentation
Direct link to the English Manual: http://products.wdc.com/library/UM/ENG/4779-705122.pdf
You’ll notice on page 110 where it discusses the Power Schedule and how it works, it clearly references a “SLIDER” function. However, if you attempt to configure on the current FW version, you can only select specific 2 hour intervals. Why is there no longer a slider function? Or better yet, just a start and end time text field box? I’m annoyed that the minimum I can set the power schedule for, is to have it shut down at 4am and turn back on at 6am. What if I only want it to be down for a 10-minute period one time per week? There doesn’t seem to be any easy way to do this…
Any help or guidance here would be most appreciated.
