I’m new to the WDTV Live Hub experience, so far so good. Howver, I can already see that disk capacity will be an issue very quickly. I’m thinking 2x3TB of additional USB attached storage so I can maintain 2 copies. I have tested connecting two small portable drives to the Hub, and works fine and Hub has the capability to copy selected objects between the drives, which I will have to do manually. II have several questions;
Is there a limit to the size of an external drive, I’m at the current FW level
Is there a limit to the number of external drives the Hub can support (If I rip my DVDs/BRs I’ll need another pair)
I plan to connect the external USB HDDs to a USB Hub connected to the rear port, the drives will be powered
PS.
My WDTV Hub is connected to to a Powerline Adapter, which is the main reason for not using a NAS + the cost of course
Thoughts/Ideas/Comments?
