I have recently maxed out my WD Readyview system with 8 cameras and am wondering what the best way to add more cameras would be. Should I just get another system or are there any other options?
Thank you!
Robert Gurney
Thank you!
Robert Gurney
If you system design with 8 network ports, then you can only use 8 cameras. The firmware is design to see 8 cameras only. You have to get another system
