Been running Raid 1 on 2 x 4TB Red WD since Oct 2017; no problems at all.
Wish to add another 4TB Red and rebuild to Raid 5, so I powered down the NAS box, added a brand new 3TB Red WD drive in slot 3.
On power up of the NAS, Disks go thu test/boot and disk 1 LED stays Blue, disk 2 LED stays blue, disk 3(which I added) LED starts blue but ends up a solid red.
Ran Disk Test: Disk3 Failed - Quick disk test Failed.
So what have I done wrong ??
I checked out the Device | Diagnostics which indicated that all 3 disk were fine.
I took the punt and rebuilt the Raid from 1 to 5 over the 3 disks.
It seems to have worked and the disk 3 LED is now Solid Blue.
Which leads to believe the disk 3 LED was solid red because it was not allocated to a Raid or other.
See how it goes reloading my configuration file and files via USB backup.
@DaveRow57 - did you get a resolution to thus … I’m running Raid 5 … Disk (WD Red) in Bay 1 of my MyCloud Ex 4100 has gone RED Led … the system auto rebuilt the Volume, but now shows 0 kB free … and all of the disks “test” ok … but still the RED Led … I’m communicating with Support (India) …
After the Raid 5 rebuild the unit has been working fine.
Thx @DaveRow57 … I think my drive must have been omitted from the auto volume rebuild ???!!???
Just to clarify - I understand that you backed up the volume to USB (mine will be 7 TB) and you then rebuilt the volume to raid 5 from scratch and included all drives?
Just checking that detail with you
Support was no help at all !!
Long time ago.
I probably did backup the disk volume(before raid 5) to an external HDD.
I do have a backup on a WD drive, as an additional backup of data.
Then added 3rd drive for a raid 5 config.
My data set is nowhere near 7GB.
Regards
David Row
27 Ashford St | Shorncliffe | Queensland 4017 | Australia
0409 531 457 | drow4@bigpond.net.au
****Please consider the environment before you print this e-mail or any attachments.
Thanks - It looks like I have “lost” the Volume after the auto-rebuild. … Something for the weekend.
